[GRASSLIST:5548] Re: v.in.ascii doesn't work on my computer
Robert S. Nuske
rnuske at gwdg.de
Thu Jan 27 16:33:03 EST 2005
Hamish,
these are the debugging messages you asked me to produce. I am sorry,
but I don't understand their meanings.
robert
> Can you enter the command:
> g.gisenv set="DEBUG=5"
> then run the v.in.ascii command
GRASS 6.0.cvs:~ > cat test.txt | v.in.ascii fs='|' out=points1 x=1 y=2
D2/5: Vect_open_new(): name = points1
D1/5: Vect_set_thresh(): thresh = 0.000000
D1/5: V1_open_new_nat(): name = points1
D1/5: Vect_get_thresh(): thresh = 0.000000
D1/5: dig__write_head()
D1/5: write coor size (0) to head
D2/5: coor body offset 14
D3/5: dig_init_plus()
D1/5: dig_spidx_init()
D3/5: dig_cidx_init()
D3/5: Vect_hist_command()
D3/5: G_recreate_command()
D5/5: Vect_hist_write()
D4/5: row 1 : 599251|4927066
D4/5: row 1 col 0: '599251' is_int = 1 is_double = 1
D4/5: row 1 col 1: '4927066' is_int = 1 is_double = 1
D4/5: row 2 : 599090|4926953
D4/5: row 2 col 0: '599090' is_int = 1 is_double = 1
D4/5: row 2 col 1: '4926953' is_int = 1 is_double = 1
D4/5: row 3 : 599097|4926472
D4/5: row 3 col 0: '599097' is_int = 1 is_double = 1
D4/5: row 3 col 1: '4926472' is_int = 1 is_double = 1
D4/5: row 4 : 599280|4925969
D4/5: row 4 col 0: '599280' is_int = 1 is_double = 1
D4/5: row 4 col 1: '4925969' is_int = 1 is_double = 1
D4/5: row 5 : 599863|4926391
D4/5: row 5 col 0: '599863' is_int = 1 is_double = 1
D4/5: row 5 col 1: '4926391' is_int = 1 is_double = 1
D4/5: row 6 : 599849|4926841
D4/5: row 6 col 0: '599849' is_int = 1 is_double = 1
D4/5: row 6 col 1: '4926841' is_int = 1 is_double = 1
Maximum input row length: 15
Maximum number of columns: 2
Minimum number of columns: 2
D3/5: Vect_build(): build = 4
Building topology ...
D2/5: dig_cidx_free()
D3/5: Vect_build_nat() build = 4
D1/5: Vect_Rewind(): name = points1
Registering lines: D3/5: Vect_read_next_line()
D3/5: V1_read_next_line_nat()
D3/5: Vect__Read_line_nat: offset = 14
0 primitives registered
0 areas built
0 isles built
Attaching islands: Attaching centroids: Topology was built.
D2/5: dig_cidx_sort()
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
D1/5: Vect_close(): name = points1, mapset = robert, format = 0, level = 2
D1/5: get coor
info:
/home/rnuske/luftbild/robert/grassdata/spearfish57/robert/vector/points1/coor
D1/5: Info->size = 14, Info->mtime = 1106861284
D1/5: Vect_save_topo()
D1/5: Open
topo:
/home/rnuske/luftbild/robert/grassdata/spearfish57/robert/vector/points1/topo
D2/5: topo body offset 142
D2/5: Vect_cidx_save()
D2/5: Open
cidx:
/home/rnuske/luftbild/robert/grassdata/spearfish57/robert/vector/points1/cidx
D3/5: dig_write_cidx_head()
D3/5: cidx body offset 13
D1/5: close history file
D1/5: V1_close_nat(): name = points1 mapset= robert
D1/5: get coor
info:
D1/5: write coor size (14) to head
D1/5: Vect_write_dblinks(): map = points1, mapset = robert
D1/5: dbln
file:
/home/rnuske/luftbild/robert/grassdata/spearfish57/robert/vector/points1/dbln
D1/5: Dblinks written
GRASS 6.0.cvs:~ >
