[GRASSLIST:7400] Re: 3d point vectors in nviz
Markus Neteler
neteler at itc.it
Fri Jul 1 02:54:51 EDT 2005
On Thu, Jun 30, 2005 at 03:32:16PM +0200, benducke at compuserve.de wrote:
> Has anyone successfully managed to get a 3D points cloud
> to display correctly in nviz?
> I checked 3D region settings and the structure of the
> vector file itself. The data and settings seem fine.
> I can display the zcoords with d.vect and it looks
> ok.
> However, when I load the map into nviz, I only get
> to see the top points of the vector map (i.e. I get
> to see as much as the top-down view by d.vect),
> the remaining points do not get displayed.
> I would very much appreciate any help!
Did you activate "3D Points" in the Vector points menu?
Markus
