[GRASSLIST:7658] Re: Compilation errors of Fedors Core 4
Markus Neteler neteler at itc.it
Thu Jul 21 05:16:34 EDT 2005
On Wed, Jul 20, 2005 at 07:47:42AM +0100, Glynn Clements wrote:
> Miha Staut wrote:
> > I tried to do as you said. So
> > make CFLAGS_WARNING= 2> std.error.txt
> > It seemed to me that no less warnings appeared (130 KB of text in all). I am
> > therefore sending the std. error output as an attachment. I am reminding again
> > that predominantly imagery commands had problems (according to error.log) while
> > for the others v.surf.rst, r.grow2, r.in.gdal (normal), r.param.scale,
> > r.resamp.rst, r.surf.gauss, r.surf.random, s.in.ascii, s.surf.rst,
> > r.hydro.CASC2D, r.surf.fractal, r.terraflow (normal).
> The first actual error is:
> numerical.h:47: error: array type has incomplete element type
> This has been fixed recently in 6.x.
I have fixed that in 5.-CVS-HEAD.
Paul, can you please update the 5.4.1-release branch (also r.flow)?
Markus
