[GRASSLIST:7665] Re: GRASS data to ArcView
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Thu Jul 21 11:40:08 EDT 2005
Hello,
thanks all for the advice. I recompiled GRASS and gdal from scratch with
support of each other. Know I can export GRASS raster to e.g. ERDAS imagine
files.
However ArcView complains that it cannot open the img file. ERDAS imagine
opens the file but tells me that float32 is not supported by layer type
"thematic" and that the spheroid "wgs84" is not recognised.
Well I think I need some more testing to find out what went wrong, but won't
be able to do before mid of august. I will reply to this thread in a couple
of weeks when I am back on this issue.
thanks so far for your help, regards, Martin
On Wednesday 20 July 2005 23:07, Markus Neteler wrote:
> > On Jul 20, 2005, at 8:10 AM, Martin Wegmann wrote:
> >> Hello,
> >> I just encountered the problem that my colleagues can't import data
> >> exported
> >> from GRASS appropriately into ArcView.
> Hi Martin,
> as Tyler says: What about r.out.gdal?
> Be warned to not forget that ESRI software apparently has limited
> GeoTIFF capabilities. To succeed, you have to change the default
> band interleave to pixel interleave (we found out, the ESRI hotline
> didn't :-).
> See (un)related thread:
>  http://article.gmane.org/gmane.comp.gis.gdal.devel/4215
> I have just added such a note to the r.out.gdal docs in CVS.
> Markus
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax:   +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
