[GRASSLIST:7671] Re: Interactive GUI input/output
    Glynn Clements
    glynn at gclements.plus.com
    Fri Jul 22 01:24:28 EDT 2005
Dave Sampson wrote:
> Using a GUI dialogue for instance r.in.gdal I sometimes find that the
> output expects an interactive input.
> That is, if you ran the same perameters from the comand line you would
> be able to enter 'list' and recive a list of options to follow on. this
> happens sometime if it asks you from a reprojection option.
> Is it possible to develop a means for interactive GUI output so a user
> does not need to drop to a comannd line to complete the task?
Modules which usually require user input are run in an xterm. The
problem is with modules which sometimes require a terminal but usually
don't. The GUI would either need to be able to determine when a
terminal is required, or it would need to always use a terminal.
