[GRASSLIST:7002] Re: v.in.dwg
Markus Neteler
neteler at itc.it
Fri Jun 3 09:52:37 EDT 2005
On Fri, Jun 03, 2005 at 12:04:48AM +0200, Adrián J. Montero Calvo wrote:
> Hello, I've downloaded opendwg, but i don't want to compile all grass 6.0. Can anybody send me a copy of v.in.dwg and v.in.dwg30 compiled? Otherwise, is it posible to compile only these modules? Thanks.
There are two options:
- if the opendwg libs are only statically distributed (.a extension),
the v.in.dwg cannot be distributed (legally)
- if the opendwg libs are also distributed as dynamic libraries
we can also distribute v.in.dwg. I didn't check for a long time,
two years ago only the static opendwg library was available.
What is the current state?
Markus
