[GRASSLIST:7062] Re: VMAP to SHAPE
Markus Neteler
neteler at itc.it
Tue Jun 7 11:37:25 EDT 2005
the upcoming GRASS newsletter (which will hopefully be published soon)
will have an article about VMAP0/ogr2ogr. It contains two scripts to
fix problems related to the VMAP0 naming scheme and the OGDI
driver in OGR.
Yes, there are differencies between v0noa and other 3 regions (in
this moment I don't remember which but the scripts in the article
should work for all regions).
If urgent, I can sent a draft of the article to you.
Markus
On Mon, Jun 06, 2005 at 07:29:38PM +0900, Masahiro ITAMOCHI wrote:
> Dear list,
> I'm working to convert VMAP0 to shape files with ogr2ogr to import to
> grass or other GIS softwares as refer to following link.
> http://intevation.de/pipermail/freegis-list/2003-June/001411.html
> On the one region, v0noa, I couldn't get expected result on some files
> listed below.
> [mitamo at localhost noamer]$ ls -l *.shp | grep 100
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 aquecanl.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 bndtxt.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 coastl.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 contourl.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 dangerp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 depthl.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqarea.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqline.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:17 dqtxt.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 elevp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 extracta.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 extractp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 hydrotxt.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:22 indtxt.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 inwatera.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 miscp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 misindp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 oceansea.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 polbnda.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 polbndl.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:13 polbndp.shp
> -rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 watrcrsl.shp
> Seeing related tables of above files contains nothing while I got no
> errors converting with ogr2ogr.
> Are there any differencies between v0noa and other 3 regions ?
> What I realized is that some directories in v0noa are capital alphabet.
> Is this the problem ?
> Someone who sucessfully converted this region, please give me an advise.
> Thanks in advance.
> Regards,
> Masahiro Itamochi
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
