[GRASSLIST:7080] Re: VMAP to SHAPE
Masahiro ITAMOCHI
masa527 at spymac.com
Wed Jun 8 10:44:11 EDT 2005
Hi Markus,
Thank you for your reply.
Your comment sounds great to solve my problem and I can wait for the
newsletter published.
Just FYI, I also tried following;
*) vpf_imp (included in NIMAMUSE)
Could convert some files to shape files.
Some were not.(coudn't read feature point or exceeding feature point error)
Very unstable on my Windows XP SP2.(freeze too many time)
Can be retrieved from http://www.mapability.com/download/nima_muse/
*) ogr2ogr in FWTools for Windows
Could locate data source.
Couldn't generate any shape files.(Different from ogr2ogr on Linux)
Anyway, I'm looking forward to see the newsletter.
Thanks kindly.
Regards,
Masahiro Itamochi
Markus Neteler wrote:
> Hi,
> the upcoming GRASS newsletter (which will hopefully be published soon)
> will have an article about VMAP0/ogr2ogr. It contains two scripts to
> fix problems related to the VMAP0 naming scheme and the OGDI
> driver in OGR.
> Yes, there are differencies between v0noa and other 3 regions (in
> this moment I don't remember which but the scripts in the article
> should work for all regions).
> If urgent, I can sent a draft of the article to you.
> Markus
> On Mon, Jun 06, 2005 at 07:29:38PM +0900, Masahiro ITAMOCHI wrote:
>>Dear list,
>>I'm working to convert VMAP0 to shape files with ogr2ogr to import to
>>grass or other GIS softwares as refer to following link.
>>http://intevation.de/pipermail/freegis-list/2003-June/001411.html
>>On the one region, v0noa, I couldn't get expected result on some files
>>listed below.
>>[mitamo at localhost noamer]$ ls -l *.shp | grep 100
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 aquecanl.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 bndtxt.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 coastl.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 contourl.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 dangerp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 depthl.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqarea.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqline.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:17 dqtxt.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 elevp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 extracta.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 extractp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 hydrotxt.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:22 indtxt.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 inwatera.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 miscp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 misindp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 oceansea.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 polbnda.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 polbndl.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:13 polbndp.shp
>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 watrcrsl.shp
>>Seeing related tables of above files contains nothing while I got no
>>errors converting with ogr2ogr.
>>Are there any differencies between v0noa and other 3 regions ?
>>What I realized is that some directories in v0noa are capital alphabet.
>>Is this the problem ?
>>Someone who sucessfully converted this region, please give me an advise.
>>Thanks in advance.
>>Regards,
>>Masahiro Itamochi
