[GRASSLIST:7096] Re: VMAP to SHAPE
Markus Neteler
neteler at itc.it
Thu Jun 9 05:59:11 EDT 2005
On Wed, Jun 08, 2005 at 11:44:11PM +0900, Masahiro ITAMOCHI wrote:
> Hi Markus,
> Thank you for your reply.
> Your comment sounds great to solve my problem and I can wait for the
> newsletter published.
It was published *today* :-)
http://grass.itc.it/newsletter/index.php
-> http://grass.itc.it/newsletter/GRASSNews_vol3.pdf
> Just FYI, I also tried following;
> *) vpf_imp (included in NIMAMUSE)
> Could convert some files to shape files.
> Some were not.(coudn't read feature point or exceeding feature point error)
> Very unstable on my Windows XP SP2.(freeze too many time)
> Can be retrieved from http://www.mapability.com/download/nima_muse/
> *) ogr2ogr in FWTools for Windows
> Could locate data source.
> Couldn't generate any shape files.(Different from ogr2ogr on Linux)
For this you may want to read the article.
Please let us know if it works.
Regards
Markus
> Anyway, I'm looking forward to see the newsletter.
> Thanks kindly.
> Regards,
> Masahiro Itamochi
> Markus Neteler wrote:
> >Hi,
> >the upcoming GRASS newsletter (which will hopefully be published soon)
> >will have an article about VMAP0/ogr2ogr. It contains two scripts to
> >fix problems related to the VMAP0 naming scheme and the OGDI
> >driver in OGR.
> >Yes, there are differencies between v0noa and other 3 regions (in
> >this moment I don't remember which but the scripts in the article
> >should work for all regions).
> >If urgent, I can sent a draft of the article to you.
> >Markus
> >On Mon, Jun 06, 2005 at 07:29:38PM +0900, Masahiro ITAMOCHI wrote:
> >>Dear list,
> >>I'm working to convert VMAP0 to shape files with ogr2ogr to import to
> >>grass or other GIS softwares as refer to following link.
> >>http://intevation.de/pipermail/freegis-list/2003-June/001411.html
> >>On the one region, v0noa, I couldn't get expected result on some files
> >>listed below.
> >>[mitamo at localhost noamer]$ ls -l *.shp | grep 100
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 aquecanl.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 bndtxt.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 coastl.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 contourl.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 dangerp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 depthl.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqarea.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqline.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:17 dqtxt.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 elevp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 extracta.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 extractp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 hydrotxt.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:22 indtxt.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 inwatera.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 miscp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 misindp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 oceansea.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 polbnda.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 polbndl.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:13 polbndp.shp
> >>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 watrcrsl.shp
> >>Seeing related tables of above files contains nothing while I got no
> >>errors converting with ogr2ogr.
> >>Are there any differencies between v0noa and other 3 regions ?
> >>What I realized is that some directories in v0noa are capital alphabet.
> >>Is this the problem ?
> >>Someone who sucessfully converted this region, please give me an advise.
> >>Thanks in advance.
> >>Regards,
> >>Masahiro Itamochi
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
