[GRASSLIST:7114] Re: VMAP to SHAPE
ITAMOCHI Masahiro
masa527 at spymac.com
Fri Jun 10 09:00:52 EDT 2005
Markus,
Thank you very much for wonderful guidance!
Your script worked very well. (^_^)b
In my case, I had to rename upper-case directory name to lower-case in
v0noa, remove the trailing '.' attached to the files as well...
Also there are so many valuable tips in this newsletter!
All these are very helpful for me.
Again, thank you for great work.
Regards,
Masahiro Itamochi
Markus Neteler wrote:
> On Wed, Jun 08, 2005 at 11:44:11PM +0900, Masahiro ITAMOCHI wrote:
>>Hi Markus,
>>Thank you for your reply.
>>Your comment sounds great to solve my problem and I can wait for the
>>newsletter published.
> It was published *today* :-)
> http://grass.itc.it/newsletter/index.php
> -> http://grass.itc.it/newsletter/GRASSNews_vol3.pdf
>>Just FYI, I also tried following;
>>*) vpf_imp (included in NIMAMUSE)
>>Could convert some files to shape files.
>>Some were not.(coudn't read feature point or exceeding feature point error)
>>Very unstable on my Windows XP SP2.(freeze too many time)
>>Can be retrieved from http://www.mapability.com/download/nima_muse/
>>*) ogr2ogr in FWTools for Windows
>>Could locate data source.
>>Couldn't generate any shape files.(Different from ogr2ogr on Linux)
> For this you may want to read the article.
> Please let us know if it works.
> Regards
> Markus
>>Anyway, I'm looking forward to see the newsletter.
>>Thanks kindly.
>>Regards,
>>Masahiro Itamochi
>>>Hi,
>>>the upcoming GRASS newsletter (which will hopefully be published soon)
>>>will have an article about VMAP0/ogr2ogr. It contains two scripts to
>>>fix problems related to the VMAP0 naming scheme and the OGDI
>>>driver in OGR.
>>>Yes, there are differencies between v0noa and other 3 regions (in
>>>this moment I don't remember which but the scripts in the article
>>>should work for all regions).
>>>If urgent, I can sent a draft of the article to you.
>>>Markus
>>>On Mon, Jun 06, 2005 at 07:29:38PM +0900, Masahiro ITAMOCHI wrote:
>>>>Dear list,
>>>>I'm working to convert VMAP0 to shape files with ogr2ogr to import to
>>>>grass or other GIS softwares as refer to following link.
>>>>http://intevation.de/pipermail/freegis-list/2003-June/001411.html
>>>>On the one region, v0noa, I couldn't get expected result on some files
>>>>listed below.
>>>>[mitamo at localhost noamer]$ ls -l *.shp | grep 100
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 aquecanl.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 bndtxt.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 coastl.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 contourl.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 dangerp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 depthl.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqarea.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:16 dqline.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:17 dqtxt.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:18 elevp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 extracta.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 extractp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 hydrotxt.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:22 indtxt.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:20 inwatera.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 miscp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:21 misindp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 oceansea.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:15 polbnda.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:14 polbndl.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:13 polbndp.shp
>>>>-rw-rw-r-- 1 mitamo mitamo 100 6 3 22:19 watrcrsl.shp
>>>>Seeing related tables of above files contains nothing while I got no
>>>>errors converting with ogr2ogr.
>>>>Are there any differencies between v0noa and other 3 regions ?
>>>>What I realized is that some directories in v0noa are capital alphabet.
>>>>Is this the problem ?
>>>>Someone who sucessfully converted this region, please give me an advise.
>>>>Thanks in advance.
>>>>Regards,
>>>>Masahiro Itamochi
