[GRASSLIST:7125] mac os x binaries and i.points
Konstantinos Theofilis theofilis at macland.gr
Sat Jun 11 19:57:59 EDT 2005
Hi list,
everytime I try to run i.points, it runs fines up to the point that
it asks for keyboard input. Then in the  i.points window the text is
garbage, so I cant read the instructions.
The same goes even if I have X11 as my graphic enviroment. I tried to
bypass the problem by starting in text mode, but it stills open a
window for i.points (I mean the command window, and not the map window).
Is this a known issue?
My system is Mac OS X 10.4
Thanks
Kostas Theofilis
