[GRASSLIST:7129] Re: mac os x binaries and i.points
Hamish
hamish_nospam at yahoo.com
Sun Jun 12 19:34:50 EDT 2005
> everytime I try to run i.points, it runs fines up to the point that
> it asks for keyboard input. Then in the i.points window the text is
> garbage, so I cant read the instructions.
> The same goes even if I have X11 as my graphic enviroment. I tried to
> bypass the problem by starting in text mode, but it stills open a
> window for i.points (I mean the command window, and not the map
> window).
> Is this a known issue?
You are using the 6.1-cvs development version, correct? I broke this a
while back and have been meaning to fix/revert the change. It's fine in
the 6.0.x line.
Solution: don't use the GUI.
To start, from the shell prompt run "i.points groupname".
Issue: I changed the module to use G_parser() & make it into a normal
GRASS module.
Temporary fix (not done yet): revert G_parser() code, add parser like
code to read arguements from the command line if given.
Outstanding issue: How to deal with interactive modules which require
keyboard input. Spawning xterms from the GUI is not a good long term
solution.
Hamish
