[GRASSLIST:7140] Importing shapefile to postgres: Problem is solved
Firman Hadi
firman_hadi at spymac.com
Mon Jun 13 06:15:19 EDT 2005
Dear Bivand, thanks for your suggestion.
It is true that the problem is related to type of data. By using the
pg.in.dbf, the field village code was assigned to integer while the data
value is longer.
So, I changed this field to character like you said, update the table by
using sql and finally the problem is solved.
Thanks again.
Cheers,
Firman Hadi
