[GRASSLIST:5994] r.bitpattern usage
Trevor Wiens
twiens at interbaun.com
Thu Mar 3 18:26:19 EST 2005
Markus was kind enough to let me have r.bitpattern (which will show up in GRASS after the 6.0 release), but I'm a bit unsure of the usage. Perhaps either he or Radim can help me with a basic use question as I want to make sure I've got this right.
I'm processing MODIS data and the bit layout is
x x x xx x x x xx xxxx xx
Now the bit of interest to me is in the 32 position which tells me if the vegetation index is still within the useful quality range.
>From my understanding I should run the command as follows:
r.bitpattern input=M2000.EVI.quality output=test pattern=32 patval=0
This will check for a 0 value in the 6 position from the right and create a layer called "test" (in my example).
Now if the value of 0 IS found the output layer's pixel value will be 1.
If the value of 0 is NOT found, the output layer's pixel value will be 0.
Right?
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
