[GRASSLIST:6865] Lat long; illegal latitude
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Tue May 24 06:05:52 EDT 2005
Hello,
this issue was already discussed a few weeks ago
(http://grass.itc.it/pipermail/grass5/2005-April/017946.html), however I do
not understand what the best work around is. Which file do I have to modify
or should it work with the most recent cvs version?
lat long location (EPSG 4326-- set up with GRASS 6 not 6.1):
Import of Lambert Azimuthal Equal-area img file (as well as UTM Wgs84 files)
failed
r.in.gdal input=/mnt/hdg1/ndvi_mask.img output=test -o -e
Over-riding projection check.
Proceeding with import...
WARNING: G_set_window(): Illegal latitude for North
Using GRASS 6.1 cvs minutes ago.
thanks in advance Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
