[GRASSLIST:6875] Re: beginner's question
Māris Nartišs
maris.nartiss at gmail.com
Tue May 24 11:41:38 EDT 2005
1. import ASCII data in to vector file (v.in.ascii);
2. create surface from imported data with v.surf.rst;
3. draw contours usin r.contour.
Most hardest part - how to find best RST tuning parameters.
Bonus - You can visualize surface from 2. step with nviz :)
Read on manual and
http://www.ing.unitn.it/~grass/conferences/GRASS2002/proceedings/proceedings/pdfs/Cebecauer_Tomas.pdf
wbr,
Maris.
On 5/24/05, Stefan Istvan <stefi at geohidroterv.hu> wrote:
> Hello list members,
> this is the first time that I write to this list. I'm a system
> administrator at a hungarian company, and I'm struggling to change the
> workstation's operating system to Linux. One of the biggest chalenge is
> to find a replacement for Golden Software's Surfer software. I found
> Grass, and I think it could be a good alternative, but it seems a little
> bit harder to use.
> Another problem is that our engineers don't want to use Linux at all, so
> it is up to me to find alternatives for their softwares.
> As far as I know, our engineers use Surfer mainly to make isolined maps
> from xyz coordinates.
> So my first question is that if I have a simple text file that contains
> x,y,z coordinates, and I would like to make an iso surface from it, how
> should I do it?
> I know that it is impossible to learn to use Grass via mailing-list, but
> I would like to get started to use it to be able to demonstrate it's
> possibilities to our engineers.
> Thank you for your help in advance,
> Istvan
