[GRASSLIST:9004] Re: v.in.ascii error
Tiago Salgueiro
1010664 at isep.ipp.pt
Fri Nov 11 09:25:16 EST 2005
Ok finally I see something...
Is not possible to see a 3D map with colours??
What I want is obtain a 3D map starting by a table of points x, y ,z. Is
it possible with GRASS?
Thanks!
Tiago
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Eva L. Hulse
Sent: quinta-feira, 10 de Novembro de 2005 20:56
To: 1010664 at isep.ipp.pt
Cc: grasslist at baylor.edu
Subject: [GRASSLIST:8988] Re: v.in.ascii error
You don't have to worry about most of those fields. You can just do:
g.region vect=testar1_out
eva.
Tiago Salgueiro wrote:
> I think it works because now I didn't got any error.
> But I don't know how to see the map. I tryed g.region but I don't know
> what to put in all fields... Can you help?
> Thanks!
> Tiago
Eva L. Hulse
PhD Student
University at Buffalo Anthropology Department evahulse at buffalo.edu
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
