[GRASSLIST:8552] Re: PostGIS and libs
Graham Watt-Gremm sunyata at uvic.ca
Sat Oct 8 14:07:28 EDT 2005
Hello Costas,
I've been through this just last week - I compiled and installed
PostgreSQL, proj4, and GEOS in their default locations, and
configured postGIS according to directions (all on OSX 10.4.2). I've
since used both GRASS (61cvs, Lorenzo's newest binaries (cheers to
lorenzo!)) and QGIS to interact with a postGIS database, including
shape manipulation and reprojection, without a hitch. Good luck with
yours...
Graham
On 8-Oct-05, at 9:19 AM, Konstantinos Theofilis wrote:
> Hi list,
> I am using Lorenzo's binaries on MacOS X 10.4.2
> Up until now I was nos not using Postgresql and PostGIS.
> I compiled PostgreSQL from source and put it in /usr/local
> Now I am trying to build postgis.
> Despite me fiddling with the config and makefiles in PostGIS source
> in order to change the DIRs for GEOS and PROJ, I couldn't make it
> to compile.
> So I am thinking of installing separate versions of GEOS and PROJ
> in /usr/local/ in order for PostGIS to find them.
> My question is: Is Postgresql/PostGIS going to work ok with GRASS ,
> despite being linked to different libs of GEOS and PROJ?
> Thanks
> Kostas
