[GRASSLIST:8263] db.test errors
Jason Horn jhorn at bu.edu
Tue Sep 13 13:51:08 EDT 2005
Does anyone know how to resolve errors that result from db.test?  For
example, see the error below:
select * from grass_test1
dbmi: Protocol error
/Applications/grass61cvs.app/Contents/Resources/grass-6.1.cvs/scripts/
db.test: line 85: 15700 Done                    echo "$SQL"
      15701 Broken pipe             | db.select -c >$result
EXECUTE: ******** ERROR ********
0a1,2
 > 1|123.456000|abcd
 > 2||xxx
RESULT: ******** ERROR ********
