[GRASSLIST:8265] Re: db.test errors
Jason Horn
jhorn at bu.edu
Tue Sep 13 15:45:50 EDT 2005
A little more information on my db problem:
I discovered that this works just fine:
db.select table=colonies database=tx_state_nad83 driver=mysql
sql="select abbrv from colonies"
However, this does not work:
sql="select * from colonies"
dbmi: Protocol error
Broken pipe
If i use a column name in the select statement, everything works
fine. If I use an * or a column name that doesn't exist, I get the
errors above, namely:
Broken pipe
I hope that sheds some light on the problem. Does anyone know what's
happening here?
- Jason
Jason Horn
Boston University Department of Biology
5 Cumington Street Boston, MA 02215
jhorn at bu.edu
office: 617 353 6987
cell: 401 588 2766
On Sep 13, 2005, at 1:51 PM, Jason Horn wrote:
> Does anyone know how to resolve errors that result from db.test?
> For example, see the error below:
> select * from grass_test1
> /Applications/grass61cvs.app/Contents/Resources/grass-6.1.cvs/
> scripts/db.test: line 85: 15700 Done echo "$SQL"
> 15701 Broken pipe | db.select -c >$result
> EXECUTE: ******** ERROR ********
> 0a1,2
> > 1|123.456000|abcd
> > 2||xxx
> RESULT: ******** ERROR ********
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050913/bafcb0d7/attachment.html
