[GRASSLIST:8264] Re: point xyz-output for cvs 6.1 (solved)
Karl Broich b61bro at b61srv5.bauv.unibw-muenchen.de
Tue Sep 13 14:15:26 EDT 2005
Thank you Hamish,
I got the column name with v.info (option : print types/names of table
columns ... ). It was the default "value". Then
v.out.ascii.db input=vpoints output=vpoints.xyz columns=value
writes the desired information as
cat | x | y | z=value
quickly (1 mio. points within less than 30 sec).
Karl
At 17:12 30.08.2005 +1200, you wrote:
> > I fail to get xyz-output from v.out.ascii on GRASS cvs 6.1.
> > Just x|y|nodeid is written.
> > Can anyone help?
>Is the z data actually a 3d coordinate or is it an attribute column?
>(check vector file type with v.info)
>If it is an attribute column you can use the v.out.ascii.db script
>available on the wiki add-ons page:
>  http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
>Hamish
Dr.-Ing. Karl BROICH			Tel:	+49 / (0) 89 / 6004 2478
Universität der Bundeswehr München	Fax:	+49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
