[GRASSLIST:8284] Re: Making road maps
Hamish
hamish_nospam at yahoo.com
Wed Sep 14 20:20:37 EDT 2005
> > 1. Is there any way to make vector lines wider when displaying them?
> > I would like to make different size vector lines for different
> > types of roads.
It's a bit of a hack, but for the normal display monitor you could use
'v.extract where=' + v.buffer + d.vect for each kind of road.
> Use ps.map to make pretty maps.
Yes, e.g.
vlines mapname
where road_type = 'big'
width 3
end
vlines mapname
where road_type = 'small'
width 1
end
also you could try loading GRASS vector maps into QGIS.
> However, after a lot of errors and searching, the "vector" command is
> no longer applicable in GRASS 6.1-cvs. You need to use the "vlines",
> "vpoints", and "vareas".
Look at "CHANGES BETWEEN VERSION 5.0.x/5.4.x and 6.0" at the start of
the ps.map help page..
> > 2. Is it possible to rotate the names/labels for my north/south
> > streets 90 degrees from the east/west streets?
'd.vect display=attr' will not rotate, but will display.
Paint Labels: (improved version in grass 6.1-cvs, not in 6.0.1)
v.label -a
ps.map, labels instruction
will align names along vector lines. Fine tune by editing the offsets in
the $MAPSET/paint/labels/$LABELS_FILE in a text editor. This should work
really well.
For the normal display monitor, d.paint.labels doesn't respect the
rotatation setting that v.label figures out & so it just draws the
labels horizontally*, but you could write a shell script that could do
it by parsing the labels file & feeding into
'd.text.freetype text= rotation=' for each feature in a loop.
This would be a really great script to have available on the GRASS Wiki
add-ons page.... fame and fortune could be yours.
[*] I have just found that we have R_text_rotation() in the raster
library.. perhaps d.paint.labels could be adapted! I will give it a try.
I am not sure if d.font.freetype would still work to make pretty fonts,
but I hope so.
good luck,
Hamish
