[GRASSLIST:8406] Re: Grass6 - Errors with v.in.ogr
    Brent Wood
    b.wood at niwa.co.nz
    Sun Sep 25 20:52:17 EDT 2005
This might be a workaround, depending on what your problem is, but you
could use ogr2ogr to convert all your Mapinfo mapfiles to ESRI shapefiles
then import the shape files?
Doesn't resolve the actual problem, but may let you keep going until it is
fixed.
Brent Wood
> Hello at all,
> I use Grass6.1.cvs and I want to import a Mapinfo table with v.in.ogr.
> When I try this command, the cover is correctly imported but when I want
> to use it, with v.to.rast or, only, with v.info, Grass informs me of an
> error "Cannot open old vector IFN25 at caba on level 2". If I try to
> display my coverage in a monitor, the display is correct but grass say
> to me : "warning : coor files of vector IFN25 at caba is larger than it
> should be Cannot display areas, topology is not avalaible". I tested
> with v.clean, v.build, import with shapefile format... same problem(s).
> I'm working with Grass6.1.cvs on Cygwin but I also try, in vain, with
> Grass6.01 (last release) on Linux (suse9.2).
> if somebody had an idea about this problem...
> Many thanks
> Jérôme Caba
> GIS Manager
> National Park of Vanoise
> FRANCE
