[GRASSLIST:754] Re: Proper configure flags for alternative install directory?
Māris Nartišs maris.nartiss at gmail.com
Wed Apr 19 03:17:42 EDT 2006
./configure --prefix=/path/to/new/install/dir
Maris.
On 4/18/06, Patton, Eric <epatton at nrcan.gc.ca> wrote:
> I'm trying to install 6.1 cvs in /opt in order to avoid overwriting an
> existing custom 6.1 install in /usr/local. I'm setting the following
> parameters during congfig to install in /opt:
> --bindir=/opt/grass-6.1.cvs/
> --program-prefix=grass61cvs
> --exec-prefix=/opt/grass-6.1.cvs/
> --libexecdir=${EPREFIX}/lib
> I'm not sure if all of these are necessary, or even set properly. When
> ./configure is finished, it reports:
> GRASS is now configured for:  i686-pc-linux-gnu
>  Source directory:            /opt/grass6
>  Build directory:             /opt/grass6
>  Installation directory:      /usr/local/grass-6.1.cvs
>  Startup script in directory: /opt/grass-6.1.cvs/
> But I don't want the install directory to be /usr/local/grass-6.1.cvs. How
> do I modify this install dir to /opt/grass-6.1.cvs?
> Thanks,
> ~ Eric.
