[GRASS-user] GRASS 6.3 on OSX
    William Kyngesburye
    woklist at kyngchaos.com
    Sun Aug 20 12:01:01 EDT 2006
OK, now that you've verified that, I guess we need to back up to the
other steps.
Could you tell if 'sudo python ez_setup.py -U setuptools' worked when
you ran it?  I don't remember what the exact output I got was.  Try
'ls /Library/Frameworks/Python.framework/Versions/2.4/bin/' and see
if the easy_install was really installed.
On Aug 20, 2006, at 10:45 AM, Agustin Diez Castillo wrote:
> On 19/08/2006, at 07:39 PM, William Kyngesburye wrote:
>> Is /Library/Frameworks/Python.framework/Versions/2.4/bin in your
>> shell PATH?
> It seems to me that it is
> echo $PATH
> /sw/bin:/sw/sbin:/usr/local/bin:/usr/local/sbin:/Library/Frameworks/
> Python.framework/Versions/2.4/bin:/Library/Frameworks/
> GDAL.framework/Programs:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/
> teTeX/bin/powerpc-apple-darwin-current:/usr/local/bin:/usr/bin/:/
> usr/sbin/:/usr/local/postgres/:/usr/local/sidgeipa/bin/:/usr/local/
> sidgeipa/bin/texturer/:/usr/local/lib/wxPython-ansi-2.6.3.3/bin:/
> usr/local/sidgeipa/bin/admin/:/usr/local/bin/:/usr/local/pgsql/:/
> usr/local/pgsql/lib:/usr/local/mysql/bin/:/Users/agus/bin:/usr/
> local/sbin:/usr/X11R6/bin
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
