[GRASS-user] [GRASSLIST:1181] d.m/d.gis mysteries..
Glynn Clements
glynn at gclements.plus.com
Thu Aug 31 08:32:29 EDT 2006
Zbigniew Perski wrote:
> Thanks a lot for response. Of course the problem I was mentioned is
> related to gis.m not d.gis - sorry about that.
> >From followed discussion I see that it is really something not easy but
> I would like to ask my questions again (in a more direct way I guess):
> 1. Is it possible to display result of grass bash script with gis.m?
> 2. If it is possible what should I modify in my scripts to be able to do
> that?
If the script is non-interactive and works with the PNG driver, you
can use a command layer to display its output.
If it requires an X monitor or terminal, you will need to modify
menu.tcl to run it as an external command.
