[GRASSLIST:10467] Re: QGIS/GRASS for Windows 060217
Manuel Seeger
seeger at uni-trier.de
Tue Feb 21 04:59:24 EST 2006
I have the same problem with qgis and grass from rpm installation on SuSe
10.0!
Spearfishh or my own rasters dont get loaded, same error warning.
Greetings from snowy germany
manuel
Am Dienstag, 21. Februar 2006 10:52 schrieben Sie:
> On 2/20/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> > > However, when trying to open any grass raster, I get the following
> > > error:
> > > "C:/..../locations//spearfish60/PERMANENT/cellhd/elevation.10m is not a
> > > supported raster data source".
> > > Is raster processing still unstable or are maybe specific read/write
> > > privileges to be set ?
> Today I tested GRASS rasters with qgis-0.7.9-win32-060217
> and Spearfish and it works for me.
> Do you have other versions of GDAL on your system?
> It should not be problem because Windows should first search for
> DLL in the directory where application is located.
> Anybody other had success/problems with GRASS rasters?
> Radim
Dr. Manuel Seeger
Wiss. Assistent Scientific Assistant
Physische Geographie Dpt. of Physical Geography
FB VI - Geographie/Geowissenschaften Geography/Geosciences
Universität Trier University of Trier
D - 54286 Trier
Tel.: +49-651-201 4557
Fax: +49-651-201 3976
Web: http://www.uni-trier.de/uni/fb6/geographie/mitarbeiter/Seeger/
