[GRASSLIST:10069] Re: v.to.db syntax
Michael Barton
michael.barton at asu.edu
Tue Jan 31 01:50:50 EST 2006
Kirk,
Here's one thought. Are the columns actually named "x" and "y"?
You need to specify real column names.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: "Kirk R. Wythers" <kwythers at umn.edu>
> Date: Mon, 30 Jan 2006 15:23:21 -0600
> To: List Users GRASS <GRASSLIST at baylor.edu>
> Cc: Blazek Radim <blazek at itc.it>
> Subject: [GRASSLIST:10057] v.to.db syntax
> Could someone expand on the syntax for the command v.to.db?
> I have a vector file that came with bad y coordinate values in the
> downloaded dbf attribute table. Therefor when I read the shape file
> into grass with v.in.ogr (I'm connected to postgresql database), the
> y value in attribute table in pg is also wrong. I want to re-write
> the y coordinates in the attribute table with the correct geometry
> from the vector file.
> I tried:
> v.to.db NAME_OF_GRASS_VECTOR option=coor col=x,y
> The command appeared to run (albit it took a while) but did not re-
> write the attibute table associated with the vector. Anyone see what
> I messed up?
> Thanks,
> Kirk
