[GRASS-user] Can't start GRASS 6.0.0
María Piquer Rodríguez almecloud at hotmail.com
Wed Jul 12 03:22:18 EDT 2006
Hello,
When installing GRASS for Windows with cygwin , at the step select your
internet connection: as Direct connection (as especified in the point 2 of
the manual http://geni.ath.cx/grass.html#toc6) I get the error: Can't get
the list of download sites. Make sure your network settings are correct and
try again.
Can anyone explain me what to do now...? should I select another internet
connection?
Thanks, thanks, thanks
María
>From: "Patton, Eric" <epatton at nrcan.gc.ca>
>To: 'María Piquer Rodríguez ' <almecloud at hotmail.com>,
>"'grassuser at grass.itc.it '" <grassuser at grass.itc.it>
>Subject: RE: [GRASS-user] Can't start GRASS 6.0.0
>Date: Tue, 11 Jul 2006 10:58:23 -0300
>Just out of curiosity, how did you install Grass 6.0? I would think that
>you
>would also need superuser privileges to install 6.0.
>~ Eric.
>-----Original Message-----
>From: grassuser-bounces at grass.itc.it
>To: grassuser at grass.itc.it
>Sent: 7/11/2006 4:44 AM
>Subject: [GRASS-user] Can't start GRASS 6.0.0
>Hello, as a new user... I guess I am getting the common problems... I
>intalled GRASS 6.0 because were I work I cannot intall 6.1 ( I cannot
>unzip
>the files of the 6.1) as I am not the complete administrator of my
>computer.
>I started to try with the shearfish data and when I try to ENTER GRASS
>it
>does not start... I get the following error:
>GRASS 6.0.0 (shearfish60):~>Error un start up script : child process
>exited
>abno rmally when executing ...
>I tried several times and I also tried to start it by using the command
>"d.m
>& ", a screen (with a detail of a map) shows up Loading data, it says
>Done
>but I get the same error again...
>Can anyone advice me what to do? Thanks
>María Piquer
>_________________________________________________________________
>Un amor, una aventura, compañía para un viaje. Regístrate gratis en MSN
>Amor
>& Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
>grassuser mailing list
>http://grass.itc.it/mailman/listinfo/grassuser
Un amor, una aventura, compañía para un viaje. Regístrate gratis en MSN Amor
