[GRASS-user] Can't start GRASS 6.0.0
Nagesh Bhatkar bnagesh at nio.org
Wed Jul 12 06:06:12 EDT 2006
Hello Maria,
Instead of installing from the internet directly , i installed it from a
CD. Found it more convinient.
First i downloaded the .iso image file and then burnt it on  a CD.
Given below is the link for downloading the .iso image file (~500MB) for
installing cygwin GRASS
https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS/CygwinGRASS-0.4.iso
This single image file when burnt onto a CD, forms the following files
and folders on it:
autorun.inf ,//setup.exe,// grass.ico, oldCygwinGRASS-0.2.1_install.pdf,
repository, //, Handbücher.//
On loading the CD on CDROM  drive, the installation process should start
automatically.
With the help of CygwinGRASS-0.2.2_install.pdf manual   i carried out
the installation./
Regards
Nagesh
María Piquer Rodríguez wrote:
> Hello,
> When installing GRASS for Windows with cygwin , at the step select
> your internet connection: as Direct connection (as especified in the
> point 2 of the manual http://geni.ath.cx/grass.html#toc6) I get the
> error: Can't get the list of download sites. Make sure your network
> settings are correct and try again.
> Can anyone explain me what to do now...? should I select another
> internet connection?
> Thanks, thanks, thanks
> María
>> From: "Patton, Eric" <epatton at nrcan.gc.ca>
>> To: 'María Piquer Rodríguez ' <almecloud at hotmail.com>,
>> "'grassuser at grass.itc.it '" <grassuser at grass.itc.it>
>> Subject: RE: [GRASS-user] Can't start GRASS 6.0.0
>> Date: Tue, 11 Jul 2006 10:58:23 -0300
>> Just out of curiosity, how did you install Grass 6.0? I would think
>> that you
>> would also need superuser privileges to install 6.0.
>> ~ Eric.
>> -----Original Message-----
>> From: grassuser-bounces at grass.itc.it
>> To: grassuser at grass.itc.it
>> Sent: 7/11/2006 4:44 AM
>> Subject: [GRASS-user] Can't start GRASS 6.0.0
>> Hello, as a new user... I guess I am getting the common problems... I
>> intalled GRASS 6.0 because were I work I cannot intall 6.1 ( I cannot
>> unzip
>> the files of the 6.1) as I am not the complete administrator of my
>> computer.
>> I started to try with the shearfish data and when I try to ENTER GRASS
>> it
>> does not start... I get the following error:
>> GRASS 6.0.0 (shearfish60):~>Error un start up script : child process
>> exited
>> abno rmally when executing ...
>> I tried several times and I also tried to start it by using the command
>> "d.m
>> & ", a screen (with a detail of a map) shows up Loading data, it says
>> Done
>> but I get the same error again...
>> Can anyone advice me what to do? Thanks
>> María Piquer
>> _________________________________________________________________
>> Un amor, una aventura, compañía para un viaje. Regístrate gratis en MSN
>> Amor
>> & Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
>> grassuser mailing list
>> http://grass.itc.it/mailman/listinfo/grassuser
> MSN Amor & Amistad.
