AW: [GRASS-user] Can't start GRASS 6.0.0
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Wed Jul 12 07:25:02 EDT 2006
Hi Nagesh and Maria,
As "producer" of the CygwinGRASS-Image I just have to point out, that it is based on a GRASS-CVS-Version from Spring 2005 (but it
works well - just doesn't inlude all the features developed since then)
Marco
> -----Ursprüngliche Nachricht-----
> Von: grassuser-bounces at grass.itc.it
> [mailto:grassuser-bounces at grass.itc.it] Im Auftrag von Nagesh Bhatkar
> Gesendet: Mittwoch, 12. Juli 2006 12:06
> An: María Piquer Rodríguez
> Cc: grassuser at grass.itc.it
> Betreff: Re: [GRASS-user] Can't start GRASS 6.0.0
> Hello Maria,
> Instead of installing from the internet directly , i
> installed it from a CD. Found it more convinient.
> First i downloaded the .iso image file and then burnt it on a CD.
> Given below is the link for downloading the .iso image file
> (~500MB) for installing cygwin GRASS
> https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS/C
ygwinGRASS-0.4.iso
> This single image file when burnt onto a CD, forms the
> following files and folders on it:
> autorun.inf ,//setup.exe,// grass.ico,
> oldCygwinGRASS-0.2.1_install.pdf, repository, //,
> Handbücher.// On loading the CD on CDROM drive, the
> installation process should start automatically.
> With the help of CygwinGRASS-0.2.2_install.pdf manual i carried out
> the installation./
> Regards
> Nagesh
> María Piquer Rodríguez wrote:
> > Hello,
> > When installing GRASS for Windows with cygwin , at the step select
> > your internet connection: as Direct connection (as
> especified in the
> > point 2 of the manual http://geni.ath.cx/grass.html#toc6) I get the
> > error: Can't get the list of download sites. Make sure your network
> > settings are correct and try again.
> > Can anyone explain me what to do now...? should I select another
> > internet connection?
> > Thanks, thanks, thanks
> > María
> >> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> >> To: 'María Piquer Rodríguez ' <almecloud at hotmail.com>,
> >> "'grassuser at grass.itc.it '" <grassuser at grass.itc.it>
> >> Subject: RE: [GRASS-user] Can't start GRASS 6.0.0
> >> Date: Tue, 11 Jul 2006 10:58:23 -0300
> >> Just out of curiosity, how did you install Grass 6.0? I
> would think
> >> that you would also need superuser privileges to install 6.0.
> >> ~ Eric.
> >> -----Original Message-----
> >> From: grassuser-bounces at grass.itc.it
> >> To: grassuser at grass.itc.it
> >> Sent: 7/11/2006 4:44 AM
> >> Subject: [GRASS-user] Can't start GRASS 6.0.0
> >> Hello, as a new user... I guess I am getting the common
> problems... I
> >> intalled GRASS 6.0 because were I work I cannot intall 6.1
> ( I cannot
> >> unzip the files of the 6.1) as I am not the complete
> administrator of
> >> my computer.
> >> I started to try with the shearfish data and when I try to ENTER
> >> GRASS it does not start... I get the following error:
> >> GRASS 6.0.0 (shearfish60):~>Error un start up script :
> child process
> >> exited abno rmally when executing ...
> >> I tried several times and I also tried to start it by using the
> >> command "d.m & ", a screen (with a detail of a map) shows
> up Loading
> >> data, it says Done but I get the same error again...
> >> Can anyone advice me what to do? Thanks
> >> María Piquer
> >> _________________________________________________________________
> >> Un amor, una aventura, compañía para un viaje. Regístrate
> gratis en
> >> MSN Amor & Amistad.
> >> http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
> >> grassuser mailing list
> >> http://grass.itc.it/mailman/listinfo/grassuser
> > Un amor, una aventura, compañía para un viaje. Regístrate gratis en
> > MSN Amor & Amistad.
