[GRASS-user] Newbie question on g.region
Matthew Perry perrygeo at gmail.com
Thu Jun 8 22:07:20 EDT 2006
Gary,
  If you don't need to match this DEM up with any existing grass data
(ie you want to create a fresh new location), you can use the
location= parameter on the r.in.gdal command to create the location
automatically based on the info contained in the DEM. Then exit out of
grass and start it back up and you should see your new location in the
list. Likewise your DEM should be imported into that location and you
can start playing with some GRASS tools.
Hope this helps a bit.
- matt
On 6/8/06, gary <lists at lazygranch.com> wrote:
> For some reason, the moderator isn't approving this message, but I'll
> post it again assuming a computer glitch.
> Yes, I know it is frustrating to deal with newbies, but we all have to
> start somewhere.
> My ultimate goal for GRASS is to do viewshed analysis with r.los. I have
> downloaded NED files from the USGS seamless website. I have also managed
> to convert the .adf file to geotiff using gdal_translate.
> My problem concerns starting up GRASS. When I try to run r.in.gdal, I
> get an error message regarding the default region is not set. I gather
> I'm not initializing GRASS properly.
> I'm using my own PC, so I can run as root to avoid directory permission
> issues.
> I have the "Grass 6 in a nutshell handy" if you need to reference it.
> Thanks in advance.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Matt Perry
http://www.perrygeo.net
