[GRASS-user] Newbie question on g.region
Trevor Wiens twiens at interbaun.com
Thu Jun 8 23:53:25 EDT 2006
On Thu, 08 Jun 2006 18:49:42 -0700
gary <lists at lazygranch.com> wrote:
> For some reason, the moderator isn't approving this message, but I'll
> post it again assuming a computer glitch.
> Yes, I know it is frustrating to deal with newbies, but we all have to
> start somewhere.
No problem.
> My ultimate goal for GRASS is to do viewshed analysis with r.los. I have
> downloaded NED files from the USGS seamless website. I have also managed
> to convert the .adf file to geotiff using gdal_translate.
> My problem concerns starting up GRASS. When I try to run r.in.gdal, I
> get an error message regarding the default region is not set. I gather
> I'm not initializing GRASS properly.
> I'm using my own PC, so I can run as root to avoid directory permission
> issues.
This shouldn't be necessary except for your install of GRASS.
> I have the "Grass 6 in a nutshell handy" if you need to reference it.
Lets cover the basics. I assume that you know the projection of the
image you want to use. Further, you've created a location which has
the same projection parameters? Now if you don't have anything in that
location yet and you are having problems, I would just delete it from
an xterm and start over. In the Grass 6 in a nutshell there is a
section on creating locations. I would review it and try again. If it
is still odd I would then use g.region -p and g.proj -p and see what
you get and how that matches or doesn't match with your file.
When you are setting up a region, you don't need to worry about extents
as their is an option in r.in.gdal to expand the extents of the current
region to match the source image.
HTH.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
