[GRASS-user] Newbie question on g.region
Hamish
hamish_nospam at yahoo.com
Fri Jun 9 05:24:47 EDT 2006
> My ultimate goal for GRASS is to do viewshed analysis with r.los. I
> have downloaded NED files from the USGS seamless website. I have also
> managed to convert the .adf file to geotiff using gdal_translate.
Can't you download NED data directly as GeoTIFF?
Some hints:
r.los doesn't scale well at all. Download "r.cva" (install with GRASS GEM?)
and use that instead if you can.
Also see hints on r.sun and r.sunmask page.
> My problem concerns starting up GRASS. When I try to run r.in.gdal, I
> get an error message regarding the default region is not set. I gather
> I'm not initializing GRASS properly.
g.setproj ?
g.region -p ?
r.in.gdal -o ?
good luck,
Hamish
