[GRASS-user] [GRASSLIST:1121] GIS-> GRASS translation page up and running
M S mseibel at gmail.com
Mon Jun 19 19:29:05 EDT 2006
i think it would be good to have some attribute marking if the command
function is identical, or deviates substantially. (for workstation command
line)
nice job on the page!  thanks this will be a great resource.
On 6/19/06, Jonathan Greenberg <jgreenberg at arc.nasa.gov> wrote:
> http://grass.gdf-hannover.de/wiki/GIS_to_GRASS_command_translation
> I decided to make the page a bit more open to other GIS packages, so if
> you
> use something besides ESRI this is the place to put your info as well --
> note that I have two levels of the Discussion on wiki, the software and
> the
> command.  If you edit this please put the GIS command (and within-page
> link)
> and the basic GRASS command in the quick reference table, but in the
> discussion copy the table from the LATTICESPOT to put the full GIS command
> (with all of the input/output variables) and the full grass command (or
> commands in a numbered list if you need > 1 grass command to replicate the
> other software's feature) with all of the grass inputs/outputs (using the
> same variable names, when possible).  You should include a "Discrepancies"
> section (bulleted) if there are any differences between the GIS software
> command and GRASS's.
> Note that for ARC-INFO commands I'm using ESRI's variable syntax copied
> directly from the ARC/INFO help manual.  It would be useful to keep up
> this
> practice for all other ARC-INFO commands.
> Any initial suggestions please let me know and I'll modify the formatting
> appropriately!  Do you think the quick-reference table needs any more
> columns, e.g. Some indication whether the external GIS command can be
> replicated "perfectly" by GRASS or if there are major differences between
> the two?
> --j
> Jonathan A. Greenberg, PhD
> NRC Research Associate
> NASA Ames Research Center
> MS 242-4
> Moffett Field, CA 94035-1000
> 650-604-5896
> AIM: jgrn307
> MSN: jgrn307 at hotmail.com
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060619/145f0f13/attachment.html
