[GRASSLIST:476] Re: Module.make
Ana Soares tiobrothercamarada at gmail.com
Thu Mar 30 06:04:59 EST 2006
Hello
Thanks for answering :-)
I've succeeded to compile the raster example with the following commands :
gcc -c -I /usr/lib/grass/include main.c
gcc -o main -L/usr/lb/grass/lib main.o -lgrass_lib -lm
But I had to remove '_' in lines such as
G_fatal_error(_("Cannot open cell file [%s]"), name);
Otherwise I would still get the PACKAGE error.
And it works! (I have no idea why... :-(
Thanks for your help ! It was difficult at first for me to understand GRASS
programming, but now I think I'm getting the hang of it! :-D
2006/3/30, Markus Neteler <neteler at itc.it>:
> Ana Soares wrote:
> > Hello
> > I've installed
> >libgrass-dev <http://packages.debian.org/unstable/libdevel/libgrass-dev>
> >using synaptic on ubuntu.
> >But, even as root,  don't have the directory
> >/usr/lib/grass/include/Make
> >so I don't have the
> >Module.make file
> >root at ubuntu:/usr/lib/grass/include# ls
> >CC.h          cdhc.h      dlg.h        graph.h      la.h
>           proto_dbmi.h  site.h
> >D.h           codes.h     dlg_bm.h     grass        label_bm.h
> >qtree.h       sitelib.h
> >G3d.h         colors.h    edit.h       gstypes.h    lapack.h
> raster.h      spawn.h
> >P_datetime.h  config.h    form.h       gsurf.h      libtrans.h
> readsites.h   sqlp.h
> >P_site.h
> >dataquad.h  geo.h        help.h       linkm.h       region_bm.h
> std_incs.h
> >Paintlib.h    datetime.h  geom.h       ibtree.h     lock.h        rowio.h
> symbol.h
> >V_.h          dbmi.h      gis.h        icon.h
> >monitors.h    rtree         transform.h
> >Vect.h        devlib.h    gisdefs.h    icon_bm.h    ogsf_proto.h  rtree.h
> vask.h
> >bdlg_bm.h     dgl         glocale.h    imagedefs.h  ortholib.h
> search.h      vbuildlib.h
> >bitmap.h      dgl.h       gmath.h      imagery.h    patterns.h
> segment.h     vect
> >blas.h        dig_atts.h  gproj_api.h  keyframe.h   pbmplus.h
> shapefil.h    version.h
> >btree.h       display.h   gprojects.h
> >  kftypes.h    portable.h    shhopt.h      winname.h
> > Can anyone help me with this problem ? Please ?
> Apparently you want to compile GRASS commands without having the GRASS
> source code.
> This wasn't possible so far, but there is a new "GRASS Extension
> Manager" in the works
> which should probably do what you want:
> http://www.uni-kiel.de/ufg/ufg_BerDucke.htm
> Maybe you give it a try and report back?
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060330/c765600e/attachment.html
