[GRASS-user] wish and other errors on start up
Fri May 12 01:16:10 EDT 2006
> Hit RETURN to continue
> Starting GRAS ...
Did you start with "grass61 -text" ?
It's trying to start the GUI version.
> WARNING: The wish command does not work as expected!
> Please check your GRASS_WISH environment variable.
> Use -help option for details.
> Switching to text based interface mode.
> Hit RETURN to continue.
Is Tcl/Tk installed? Does "wish" work from the command line?
 (needed for the optional GUI menus, not for plain old x-monitors)
> /usr/lib/grass/set_data: /lib/libc.so.6: version 'GLIBC_2.3' not found
> (required by /usr/lib/grass/lib/libgrass_gis.so)
ouch.
Hamish
