[GRASS-user] help with vector handling needed
Wolfgang Zillig
wollez at gmx.net
Mon May 29 15:49:09 EDT 2006
Hi all,
I've downloaded an e00 file with the outline from Laos. Import worked
finally an I get it displayed as it should be. But now I wanted to
export the map to an dxf file so that I can add some labels and fill the
outline with a color. But when I import the dxf to corel draw it is
composed of line segments (72 pieces) and I can't group them so that a
filling of the area is possible. I think one problem is that the
direction of the lines is not always in the same direction. So here my
questions:
- how can I alter the vector file in grass so that I get a closed outline?
- is there an other resource of country boundaries which is more easily
usable?
- what software would you reccomend to draw simple maps (boundary
outline, different locations marked by symbols and some text needs to be
added as well)?
- is there a GUI-viewer/editor for the database files available (at the
moment I use the standard dbf files)?
thanks for any help
Wolfgang
