[GRASS-user] groups and subgroups
Travis Kirstine
traviskirstine at gmail.com
Mon Oct 16 13:10:16 EDT 2006
Hi all,
I'm a fairly new user to grass and am trying to test classify imagery
using unsupervised and supervised classification techniques, however
I'm looking for some clarification in grouping imagery using i.group.
My basic understanding is that a group is a set of imagery i.e RGB,
PAN, NIR ... what then is the subgroup?
The data that I'm analyzing is digital orthophoto acquired using
vexcel ultracam and has the following spectral resolution:
BLUE 390-470nm
GREEN 420-580nm
RED 620-690nm
NIR 690-900nm
I've import the files into grass with the following names
area1_cir_band1 (near infrared band) seperate dataset
area1_rgb.red
area1_rgb.green
area1_rgb.blue
I believe that after importing grass goups the RGB automatically
I then grouped all the datasets using i.group to area1_group
Is that correct? If so what is the subgroup?
Any information would be much appreciated
Cheers
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
