[GRASS-user] Cannot save map display as anything but ppm image
Michael Barton
michael.barton at asu.edu
Tue Sep 12 16:08:21 EDT 2006
What happens when you type gdal_translate from the GRASS command prompt?
If you get the same error, you may need to make sure that
/usr/local/grasslib/bin/ is in your PATH variable.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Tue, 12 Sep 2006 12:50:43 -0500
To: <grassuser at grass.itc.it>
Subject: [GRASS-user] Cannot save map display as anything but ppm image
When I try to save my map display as any kind of image (tiff, bmp, jpeg), it
displays an error "couldn't execute gdal_translate: no such file or
directory" and saves it as a ppm image. I do have gdal_translate, it is
located in /usr/local/grasslib/bin/.
1. Is this not the usual place for gdal_translate?
2. If it is, why can Grass not find it? Is there some sort of environment
variable that needs to be set?
Thanks,
Romy
Romy Schneider
Visualization Specialist
Texas Advanced Computing Center
The University of Texas at Austin
http://www.tacc.utexas.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060912/4aa85875/attachment.html
