[GRASS-user] Cannot save map display as anything but ppm image
Romy Schneider
romy at tacc.utexas.edu
Wed Sep 13 11:16:28 EDT 2006
Yeah, it says command not found. I added the path to my PATH
variable, and that fixed it. Thanks.
On Sep 12, 2006, at 3:08 PM, Michael Barton wrote:
> What happens when you type gdal_translate from the GRASS command
> prompt?
> If you get the same error, you may need to make sure that /usr/
> local/grasslib/bin/ is in your PATH variable.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> From: Romy Schneider <romy at tacc.utexas.edu>
> Date: Tue, 12 Sep 2006 12:50:43 -0500
> To: <grassuser at grass.itc.it>
> Subject: [GRASS-user] Cannot save map display as anything but ppm
> image
> When I try to save my map display as any kind of image (tiff, bmp,
> jpeg), it displays an error "couldn't execute gdal_translate: no
> such file or directory" and saves it as a ppm image. I do have
> gdal_translate, it is located in /usr/local/grasslib/bin/.
> 1. Is this not the usual place for gdal_translate?
> 2. If it is, why can Grass not find it? Is there some sort of
> environment variable that needs to be set?
> Thanks,
> Romy
> Romy Schneider
> Visualization Specialist
> Texas Advanced Computing Center
> The University of Texas at Austin
> http://www.tacc.utexas.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060913/9b2c22b0/attachment.html
