[GRASS-user] MS-Windows native GRASS & shell scripts
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue Sep 26 06:28:05 EDT 2006
Roger Bivand wrote:
> On Mon, 25 Sep 2006, Luigi Ponti wrote:
>> Dear list,
>> I have finally found some time to install the new native winGRASS by
>> Huidae Cho and it was OK.
>> I was wondering if it is possible to run some scripts I wrote (bash
>> scripts, containing calls to perl scripts that also use gnuplot) under
>> the new winGRASS. Based on my ignorance, this sounded to me like
>> impossible (since it is a Minimalist GNU), then I read in the MinGW
>> FAQ's that you could...
> I think you need first to read up on MSYS, which can provide what you need
> in a simpler way than Cygwin. The MS-Windows native binary is actually an
> MSYS build - MSYS provides enough shell-level support to run configure
> scripts. If Windows Perl and gnuplot are available in your path, they
> should also integrate well enough. There are issues with the ordering of
> directories in the path, which is not always simple, but may be less of a
> problem than using Cygwin.
> A concern that I have had is that the current installation is rather
> invasive - I already have MinGW and MSYS (and tcltk), and build proj4 and
> GDAL there anyway, but the install procedure seems to assume a "bare"
> platform - is it possible to respect the fact that some software may
> already be present? By the way, I think PostgreSQL is absolute overkill
> for Windows.
I agree, but Huidae said:
 > PostgreSQL is required since some of modules are linked against their
 > libraries.
Huidae, would it be possible to limit this to some runtime libraries,
and not the entire postgresql server ?
Also, it might be interesting to put compiling instructions on the web,
so that people could compile without Postgresql support if they wanted to.
I also find that MSYS is a pretty heavy dependency (several hundreds of
MB...). Could that be trimmed down in any way ?
Moritz
