[GRASS-user] Description of WILDFIRE
Rainer M Krug Rainer.grass at krugs.de
Mon Dec 10 08:35:45 EST 2007
Hi Ljiljana
thanks for your response
Ljiljana Bodrožić wrote:
> These  modules are performing rate of spread calculationons for each
> cell based on Rothermel equation for rate of spred (r.ros) and then
> performing 2D eliptical spread simulation.
> Fuel model used in this module is 13 category model defined by Anderson
> and described in
> http://www.firemodels.org/downloads/behaveplus/publications/Anderson_INT-122_1982.pdf
That is exactlyu what I was looking for - thanks.
> I am using the module in my work, but I am using grass 5.7 becouse when
> I use higher version of grass the r.spread freezes, and I still didn't
> get the answer why.
Oops - I am using 6.2.3 at the moment - I will definitely keep you posted.
> If you notice that the new version  of grass is performing r.spread
> without failure please let me know :)
Sure
regards,
Rainer
> best regards
> Ljiljana Bodrozic
> Department for modeling and inteligent systems
> Faculty of Electrical Engineering, Mechanical Engineering and Naval
> Architecture
> University of Split
> Rainer M Krug wrote:
>> Hi
>> I am looking for a description of the layers needed and what they
>> represent and how the module r.ros, r.spread are calculating the
>> spread of fires. Especially a definition of the fuel model would be
>> usefull.
>> Is there something like that available online?
>> Thanks
>> Rainer
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
