[GRASS-user] Creating a ground water from a vector files of
contours?
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Tue Feb 6 18:23:53 EST 2007
Hi Dylan,
Looks like I was asking the computer to eat more then it can chew :-) I have tried a smaller area and v.surf.rst did finish in good time. Now I have another problem. v.surf.rst seem to ignore the contours, but it noticed the centroids. I see a bunch of bulls-eyes all over my map. I guess I have missed a step?
Bob
-----Original Message-----
From: Dylan Beaudette [mailto:dylan.beaudette at gmail.com]
Sent: Monday, February 05, 2007 1:39 PM
To: grassuser at grass.itc.it
Cc: Moskovitz, Bob
Subject: Re: [GRASS-user] Creating a ground water from a vector files of
contours?
Hi Bob,
What have you defined your region as: i.e. what is the cell size, and what
sort of area are you dealing with? If the cell size is too small, or your
have defined a very large area, then v.surf.rst will take a very long time --
possibly producing a finer grid than really needed.
That aside, contour data can sometimes be a troublesome source for an
interpolation. Also, for VERY large datasets (small resolution / large area)
you might try some other interpolator. check the archives for some ideas.
Cheers,
Dylan
On Monday 05 February 2007 12:50, Moskovitz, Bob wrote:
> Hello Grassusers,
> Like the subject line says, I need help creating a ground water map using a
> vector file of contours. The ground water file came from a E00 file that
> was read into Grass using v.in.e00. I am currently running v.surf.rst
> which is taking a long time to run. Are there other ways to do this
> problem?
> Thanks in advance,
> Bob
> Bob Moskovitz
> Seismic Hazards Zonation Program
> California Geological Survey
> http://gmw.consrv.ca.gov/shmp
> CONFIDENTIALITY NOTICE: This communication is intended only for the use of
> the individual or entity to which it is addressed. This message contains
> information from the State of California, California Geological Survey,
> which may be privileged, confidential and exempt from disclosure under
> applicable law, including the Electronic Communications Privacy Act. If the
> reader of this communication is not the intended recipient, you are hereby
> notified that any dissemination, distribution, or copying of this
> communication is strictly prohibited.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
