[GRASS-user] Problems with r.le.setup
Hamish
hamish_nospam at yahoo.com
Thu Feb 8 20:24:22 EST 2007
Andrew wrote:
> I'm definitely using grass63 cvs (weekly snapshot from last week)
> The error occurs when through the last stage of the interactive menu
> within the program. (I simply typed r.le.setup at the prompt)
Can you be more explicit? What is the exact text of the prompt you see,
what keystrokes do you use to get there, etc. There are a number of
interactive menus within the setup module.
> I will try and use the more full command "r.le.setup map= vect= "
> instead.
> However, I would be interested in using the new r.li commands but am
> confused on how I can get grey-scale type texture attributes out of
> them (seems like its more fragmentation statistics than texture)
> Any suggestions on how to do that would be appreciated.
> At the moment I have reverted to using r.texture but that runs across
> the whole raster and tends to blow out my memory. I really want to
> only calculate texture at about 100 points - so the centered on sites
> options in r.le and r.li are useful.
(no idea)
Hamish
