[winGRASS] Re: [GRASS-user] Re: Xganim errors in WinGRASS
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Feb 9 09:43:03 EST 2007
On Fri, 9 Feb 2007, Moritz Lennert wrote:
>>>> (general call for packagers)
>>>> It would sure be nice if someone produced a GRASS 6.2.1 Cygwin binary.
>>>> Currently the most up-to-date binary available for the Cygwin version
>>>> is 6.1-cvs April 17, 2006. i.e. there is still no stable GRASS 6.2
>>>> available for Windows users -- what's the problem? shared libs?
>>> I think this is mainly due to the fact that we are not very far from a
>>> real native windows version. I think dev efforts should rather be put into
>>> that.
>> Actually, I'd say that we're still quite a long way from having a
>> *usable* native Windows version.
>> Most of the people who have contributed to the native version don't
>> normally use Windows[1]. Thus, they aren't likely to be as motivated
>> to solve issues as would someone who actually has a *need* for a
> Just to add to this: I think it is time that we publish a more recent version
> of WinGRASS. The one which people get to now from the downloads page is way
> out of date and any current version would be better than that. In addition,
> this would allow us to have more alpha-testers.
Yes, Huidae's version is more Msys-GRASS than Windows-GRASS. It depends on
having Msys installed, also depends on various Msys-related modifications
to the source code which have been removed now.
> Paul, as you are the one working most closely on WinGRASS do you want to do
> this ?
I don't like the idea of putting out a version that has the vector-DB
connectivity completely broken. I think it would give a bad impression.
Apart from that it would not be too hard to do. You could include the
Mingw Tcl/Tk within the distribution too, and the required libraries
(GDAL, PNG etc.) It could just be a big zip file that could be unzipped
anywhere, with only the path in grass63.bat needing to be changed to suit
it. grass63.bat could be saved anywhere and then a desktop shortcut
created to start it up.
Paul
