[winGRASS] Re: [GRASS-user] Re: Cygwin winGRASS 6.2 Errors!
Glynn Clements
glynn at gclements.plus.com
Thu Feb 15 06:44:03 EST 2007
Hamish wrote:
> > The above behaviour (program does nothing) used to occur when building
> > with DLLs.
> > Unfortunately, it works on my system, so I probably can't be of much
> > help in tracking down the problem.
> I'll install gdb + cygwin's version of ldd* and see if I can find
> anything. You didn't optimize & strip the binaries did you?
I used the default flags, i.e. "-g -O2". So, the binaries will have
debug info, but will also be optimised.
FWIW, the complete configure command is:
./configure --with-proj-share=/usr/share/proj --with-cxx --with-motif
--with-freetype --with-nls --with-readline
--with-freetype-includes=/usr/include/freetype2 --with-postgres
--with-tcltk-includes=/usr/local/include
--with-tcltk-libs=/usr/local/lib
> looking at the programs which didn't build, it seems to be a problem
> with these libs:
> $(GPROJLIB)
> $(VECTLIB)
Both require GDAL, which requires a load of stuff; in this case:
glynn at WXP:~ $ cygcheck /usr/local/bin/cyggdal-1.dll
C:/cygwin/usr/local/bin/cyggdal-1.dll
C:\cygwin\bin\cygwin1.dll
C:\WINDOWS\system32\ADVAPI32.DLL
C:\WINDOWS\system32\ntdll.dll
C:\WINDOWS\system32\KERNEL32.dll
C:\WINDOWS\system32\RPCRT4.dll
C:\cygwin\bin\cygjasper-1-701-1.dll
C:\cygwin\bin\cygjpeg-62.dll
C:\cygwin\bin\cygpng12.dll
C:\cygwin\bin\cygz.dll
C:\cygwin\bin\cygpq.dll
C:\cygwin\bin\cygcrypt-0.dll
C:\cygwin\bin\cygcrypto-0.9.8.dll
C:\cygwin\bin\cygintl-3.dll
C:\cygwin\bin\cygiconv-2.dll
C:\cygwin\bin\cygssl-0.9.8.dll
C:\cygwin\bin\cygtiff-5.dll
For a sample program:
glynn at WXP:~ $ cygcheck /usr/local/grass-6.2.1/bin/g.proj
C:/cygwin/usr/local/grass-6.2.1/bin/g.proj
C:\cygwin\bin\cygproj-0.dll
C:\cygwin\usr\local\bin\cyggdal-1.dll
C:\cygwin\usr\local\grass-6.2.1\lib\libgrass_gis.6.2.1.dll
C:\cygwin\bin\cygintl-8.dll
C:\cygwin\usr\local\grass-6.2.1\lib\libgrass_datetime.6.2.1.dll
C:\cygwin\usr\local\grass-6.2.1\lib\libgrass_gproj.6.2.1.dll
IOW, everything GDAL needs, plus cygproj-0.dll and cygintl-8.dll.
> $(IMAGERYLIB)
> $(GMATHLIB)
IMAGERYLIB requires GMATHLIB, which requires FFTW.
> Interesting, the order of libs in the Makefile is causing trouble:
> #doesn't work
> PGM = i.pca
> LIBES = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB)
> #works
> PGM = i.his.rgb
> LIBES = $(IMAGERYLIB) $(GISLIB) $(GMATHLIB)
Actually, the first one is correct, although the only libgis functions
which the gmath library uses are the standard utilities (G_malloc,
G_fatal_error etc), which will get pulled in anyhow.
> > FWIW; here is the output from "env | sort":
> will diff for anything obvious.
> by the way, exit code 53 is missing DLLs:
> http://www.cygwin.com/ml/cygwin/2006-10/msg00921.html
That figures. It would be nice if it told you that, or which ones were
missing.
