[GRASS-user] v.external and POSTGIS
Gustavo Martínez
gumartin at mecon.gov.ar
Thu Feb 15 12:54:01 EST 2007
Hello Stephan,
I've already verified that and v.in.ogr lists PostgreSQL as one of the
available formats and also the command you suggested.
Gustavo
En Thu, 15 Feb 2007 12:40:42 -0300, Stephan Holl
<stephan.holl at intevation.de> escribió:
> Hello Gustavo,
> Gustavo Martínez <gumartin at mecon.gov.ar>, [20070215 - 12:11:13]
>> Hello all,
>> I'm starting with POSTGIS and GRASS and I have some problems with
>> v.external.
>> My computer is running Debian 'testing' AMD64 with GRASS 6.2.0,
>> Postgresql 8.1 and Postgis 1.1.6, all from debian packages.
>> On Postgres, I have a table named vms with column geometry storing
>> POINTS. If I connect from GRASS to the database the connection is
>> successful:
>> db.tables driver=pg database=host=localhost,dbname=pesca
>> public.geometry_columns
>> public.spatial_ref_sys
>> public.vms
>> When I use v.external:
>> v.external dsn='PG:host=localhost user=gumartin dbname=pesca'
>> output=pp layer=vms
>> Cannot open data source
>> Can anybody help me with this? What am I doing wrong?
> This are 2 pairs of shoes. db.tables uses GRASS pg-driver while
> v.external uses the OGR-based postgresql-driver.
> So it seems that you build grass with postgresql-support, but not your
> underlaying gdal/ogr-library?!
> You could check if your ogr is linked against postgresql by typing
> ogrinfo --formats|grep -i postgres
> HTH
> Stephan
Lic. Gustavo Martínez
Sub Secretaría de Pesca de la Nación
Paseo Colón 922 Of. 329
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
