Fwd: Re: [GRASS-user] v.external and POSTGIS
Gustavo Martínez gumartin at mecon.gov.ar
Thu Feb 15 13:04:27 EST 2007
Hello,
I forgot to mention that I've tried QGIS from inside GRASS and I had no
problem in accessing the same data.
Gustavo
> Gustavo Martínez <gumartin at mecon.gov.ar>, [20070215 - 12:11:13]
>> Hello all,
>> I'm starting with POSTGIS and GRASS and I have some problems with
>> v.external.
>> My computer is running Debian 'testing' AMD64 with GRASS 6.2.0,
>> Postgresql 8.1 and Postgis 1.1.6, all from debian packages.
>> On Postgres, I have a table named vms with column geometry storing
>> POINTS. If I connect from GRASS to the database the connection is
>> successful:
>> db.tables driver=pg database=host=localhost,dbname=pesca
>> 	public.geometry_columns
>> 	public.spatial_ref_sys
>> 	public.vms
>> When I use v.external:
>> v.external dsn='PG:host=localhost user=gumartin dbname=pesca'
>> output=pp layer=vms
>> 	Cannot open data source
>> Can anybody help me with this? What am I doing wrong?
Lic. Gustavo Martínez
Sub Secretaría de Pesca de la Nación
Paseo Colón 922 Of. 329
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
