[GRASS-user] v.net.path through gis manager (GRASS6.2)
    Moritz Lennert
    mlennert at club.worldonline.be
    Tue Feb 20 11:06:15 EST 2007
On 20/02/07 15:21, Aldo Clerici wrote:
> Dear GRASSusers,
> I'm trying to use v.net.path through gis manager (GRASS6.2) to define the
> shortest path between two points of given coordinates, but the panel of the
> command seems not to allow the coordinates input, even though the
> description of the last parameter in the panel reports explicitly this
> possibility 'Maximum distance to the network if start/end are given as
> coordinates'
> In command line mode the following works:
> v.net.path in=roads ou=roads_pt <<end
>> 1 592634 4925356 596568 4922912
>> 2 591738 4923061 593170 4915608
>> end
> Is there a way to perform the same operation using gis manager?
You can define a command layer and in this layer use something like:
echo "1 592634 4925356 596568 4922912 2 591738 4923061 593170 4915608" |
(don't know if you need to add a separator between the points)
Moritz
